[GRASS-dev] GRASS 7.8.5 compile errors
Thomas Adams
tea3rd at gmail.com
Thu Aug 12 10:00:22 PDT 2021
Hi Māris,
Thank you. I did earlier find that I did have two proj libraries, so I
removed libproj.so.15. I also ran sudo ldconfig. I also tried removing from
my config anything that I had not explicitly compiled from source against
proj that I compiled, giving:
CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
--enable-64bit \
--with-cxx \
--enable-largefile=yes \
--with-nls \
--with-readline \
--with-pthread \
--with-gdal=/usr/local/bin/gdal-config \
--with-proj --with-proj-share=/usr/local/share/proj \
--with-proj-includes=/usr/local/include \
--with-proj-libs=/usr/local/lib \
--with-geos=/usr/local/bin/geos-config \
--with-wxwidgets=/usr/local/bin/wx-config \
--with-cairo \
--with-opengl-libs=/usr/include/GL \
--with-freetype=yes \
--with-freetype-includes=/usr/include/freetype2/ \
--with-postgres=yes \
--with-postgres-includes=/usr/local/include \
--with-sqlite=yes \
--with-mysql=yes \
--with-mysql-includes=/usr/include/mysql \
--with-odbc=no \
--with-netcdf=/usr/local/bin/nc-config \
--with-zstd \
--with-zstd-includes=/usr/local/include \
--with-zstd-libs=/usr/local/lib
Still I get the errors and when I run ldd, I get...
teaiii at tea-Leopard-WS:~/grass-7.8.5$ ldd
/home/teaiii/grass-7.8.5/dist.x86_64-pc-linux-gnu/lib/libgrass_gproj.so |
grep proj
libproj.so.19 => /usr/local/lib/libproj.so.19 (0x00007fb0030a1000)
libproj.so.15 => not found
It's a mystery where libproj.so.15 references are coming from. I have never
had this kind of problem before.
Tom
On Thu, Aug 12, 2021 at 12:39 PM Maris Nartiss <maris.gis at gmail.com> wrote:
> Hello Thomas,
> I gave you a wrong path. Try this one:
> ldd /home/teaiii/grass-7.8.5/dist.x86_64-pc-linux-gnu/lib/libgrass_gproj.so
> The problem still boils down to having different incompatible system
> libraries during compilation and runtime. You can also search for
> libproj.so files in /usr/lib(64) or just dpkg -l | grep proj and if
> you see multiple proj versions, remove one.
> Māris.
> 2021-08-12 13:11 GMT+03:00, Thomas Adams <tea3rd at gmail.com>:
> > Hi Māris,
> > When I run the command ldd
> /home/teaiii/grass-7.8.5/lib/libgrass_gproj.so |
> > grep proj , I get:
> > ldd: /home/teaiii/grass-7.8.5/lib/libgrass_gproj.so: No such file or
> > directory
> > There is no libgrass_gproj.so file in /home/teaiii/grass-7.8.5/lib/l in
> > fact just subdirectories along with Makefile and README
> > Tom
Thomas E Adams, III
207 Chowning Place
Blacksburg, VA 24060
tea3rd at gmail.com (personal)
tea at terrapredictions.org (work)
1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210812/eabbd798/attachment.html>
