[GRASS-dev] GRASS 7.8.5 compile errors
Even Rouault
even.rouault at spatialys.com
Thu Aug 12 10:03:07 PDT 2021
It might be possible that your GDAL build is linking against libgeotiff
and/or libspatialite built against libproj.so.15
Le 12/08/2021 à 19:00, Thomas Adams a écrit :
> Hi Māris,
> Thank you. I did earlier find that I did have two proj libraries, so I
> removed libproj.so.15. I also ran sudo ldconfig. I also tried removing
> from my config anything that I had not explicitly compiled from source
> against proj that I compiled, giving:
> CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
> --enable-64bit \
> --with-cxx \
> --enable-largefile=yes \
> --with-nls \
> --with-readline \
> --with-pthread \
> --with-gdal=/usr/local/bin/gdal-config \
> --with-proj --with-proj-share=/usr/local/share/proj \
> --with-proj-includes=/usr/local/include \
> --with-proj-libs=/usr/local/lib \
> --with-geos=/usr/local/bin/geos-config \
> --with-wxwidgets=/usr/local/bin/wx-config \
> --with-cairo \
> --with-opengl-libs=/usr/include/GL \
> --with-freetype=yes \
> --with-freetype-includes=/usr/include/freetype2/ \
> --with-postgres=yes \
> --with-postgres-includes=/usr/local/include \
> --with-sqlite=yes \
> --with-mysql=yes \
> --with-mysql-includes=/usr/include/mysql \
> --with-odbc=no \
> --with-netcdf=/usr/local/bin/nc-config \
> --with-zstd \
> --with-zstd-includes=/usr/local/include \
> --with-zstd-libs=/usr/local/lib
> Still I get the errors and when I run ldd, I get...
> teaiii at tea-Leopard-WS:~/grass-7.8.5$ ldd
> /home/teaiii/grass-7.8.5/dist.x86_64-pc-linux-gnu/lib/libgrass_gproj.so
> | grep proj
> libproj.so.19 => /usr/local/lib/libproj.so.19 (0x00007fb0030a1000)
> libproj.so.15 => not found
> It's a mystery where libproj.so.15 references are coming from. I have
> never had this kind of problem before.
> Tom
> On Thu, Aug 12, 2021 at 12:39 PM Maris Nartiss <maris.gis at gmail.com
> <mailto:maris.gis at gmail.com>> wrote:
> Hello Thomas,
> I gave you a wrong path. Try this one:
> ldd
> The problem still boils down to having different incompatible system
> libraries during compilation and runtime. You can also search for
> libproj.so files in /usr/lib(64) or just dpkg -l | grep proj and if
> you see multiple proj versions, remove one.
> Māris.
> 2021-08-12 13:11 GMT+03:00, Thomas Adams <tea3rd at gmail.com
> <mailto:tea3rd at gmail.com>>:
> > Hi Māris,
> > When I run the command ldd
> /home/teaiii/grass-7.8.5/lib/libgrass_gproj.so |
> > grep proj , I get:
> > ldd: /home/teaiii/grass-7.8.5/lib/libgrass_gproj.so: No such file or
> > directory
> > There is no libgrass_gproj.so file in
> /home/teaiii/grass-7.8.5/lib/l in
> > fact just subdirectories along with Makefile and README
> > Tom
> Thomas E Adams, III
> 207 Chowning Place
> Blacksburg, VA 24060
> tea3rd at gmail.com <mailto:tea3rd at gmail.com> (personal)
> tea at terrapredictions.org <mailto:tea at terrapredictions.org> (work)
> 1 (513) 739-9512 (cell)
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210812/39f92a50/attachment-0001.html>
