GRASS supports arbitrary band reference names. Just make them unique enough to not mix together apples with oranges by accident (e.g. "min" is a bad idea, "min_t_c" is better; "NDVI" would work; "elevation" – bad, "elevation_m" – better). You can set band references after import with r.support module. Have fun, Māris.
