[GRASS-dev] lib/gis/band_reference.c ?
Maris Nartiss maris.gis at gmail.com
Tue Aug 24 02:09:33 PDT 2021
Band reference rules were totally relaxed 7 days a go:
https://github.com/OSGeo/grass/commit/abe194dce78adf5f63885a6a09c452fc7ae4f735
New relaxed rule changes haven't propagated to the documentation yet
(PR's welcome).
Band reference editing via r.support was added on 4th of July:
https://github.com/OSGeo/grass/commit/ca1551206eaa0fc462f4849a06ebb035808470da
Still – keep in mind – there are no changes in band metadata as
managed by g.bands. Changes only deal with ability to have a band
reference without extended metadata in json files. Thus limitation of
not being able to define your own band reference is still in place,
now only you can assign a band reference without having a definition
(and thus any extended metadata apart from its name).
Māris.
2021-08-24 11:18 GMT+03:00, Stefan Blumentrath <Stefan.Blumentrath at nina.no>:
> Thanks Maris for the reply.
> I could not find that option in r.support.
> i.band allows to add e.g. S2_12 as band reference, but nothing custom. And
> the g.bands manual says that user-defined band references are not yet
> supported.
> Has that been added recently? Or would I have to edit the bands json file of
> the system first?
> My system is:
> g.version -ger
> version=8.0.dev
> date=2021
> revision=dd9d36830
> build_date=2021-07-08
> build_platform=x86_64-pc-linux-gnu
> build_off_t_size=8
> libgis_revision=d2a5e8e8f
> libgis_date=2021-06-16T04:05:21+00:00
> proj=7.0.0
> gdal=3.0.4
> geos=3.8.0
> sqlite=3.22.0
> Cheers
> Stefan
> -----Original Message-----
> From: Maris Nartiss <maris.gis at gmail.com>
> Sent: tirsdag 24. august 2021 09:03
> To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
> Cc: Martin Landa <landa.martin at gmail.com>; Markus Metz
> <markus.metz.giswork at gmail.com>; GRASS developers list
> <grass-dev at lists.osgeo.org>
> Subject: Re: [GRASS-dev] lib/gis/band_reference.c ?
> GRASS supports arbitrary band reference names. Just make them unique enough
> to not mix together apples with oranges by accident (e.g. "min"
> is a bad idea, "min_t_c" is better; "NDVI" would work; "elevation" – bad,
> "elevation_m" – better).
> You can set band references after import with r.support module.
> Have fun,
> Māris.
