[GRASS-dev] r.statistics being deprecated?
Anna Petrášová kratochanna at gmail.com
Sat Feb 6 19:24:08 PST 2021
On Thu, Feb 4, 2021 at 5:44 PM Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Feb 4, 2021 at 8:19 PM Michael Barton <Michael.Barton at asu.edu>
> wrote:
> > r.statistics no longer appears in the menu for GRASS 7.8.6 (and
> earlier?).
> > Is it being deprecated and replaced by r.stats.zonal?
> I am not aware of that but indeed I don't see it in the menu under
> Raster > Reports and statistics
> Was it ever therein?
> Regarding replacement:
> https://grass.osgeo.org/grass79/manuals/r.stats.zonal.html#notes
> "r.stats.zonal is intended to be a partial replacement for
> r.statistics, with support for floating-point cover maps at the
> expense of not supporting quantiles."
See also https://lists.osgeo.org/pipermail/grass-dev/2014-March/068038.html
I believe r.statistics could be removed (perhaps moved to addons). It is
replaced by r.stats.zonal for the most part, and also r.stats.quantile and
r.mode.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210206/0e87e031/attachment.html>
