[GRASS-dev] Docker builds
Markus Neteler
neteler at osgeo.org
Fri Feb 19 01:03:48 PST 2021
On Fri, Feb 19, 2021 at 12:23 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Thu, Feb 18, 2021 at 4:09 PM Markus Neteler <neteler at osgeo.org> wrote:
>> On Thu, Feb 18, 2021 at 9:15 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> > Dear all,
>> > Docker build which runs on each commit in master branch on hub.docker.com fails.
>> I don't see any failures in hub.docker.com under our (mundialis) account.
>> I just see a long queue of builds in the pipeline due to the high
>> amount of commits in the last few hours.
>> > I'm not managing these builds,
>> Do you refer to the builds made my mundialis? Carmen and I take care.
> I guess so. I refer to those which you can see in commits on master branch. See attached.
>> Unfortunately the link under the red X in [1] is broken: 404.
> That's what I get, but I thought it is something you need to log into first to see that.
>> > so I see only that something starting with ci/dockercloud-stage (/docker/alpine/Dockerfile_` fails in the.
>> > The ones which are substantially different from what we test on GitHub should be tested there for each PR using GH workflow. On the other hand, if there is no way of fixing it and/or no need for them, the best course of action is to remove them. Each commit on master branch now shows as a failure [1].
>> > Vaclav
I found it: docker/alpine/Dockerfile_alpine_wxgui builds fail.
I have deactivated the builds now in dockerhub and suggest to drop the
file entirely:
https://github.com/OSGeo/grass/pull/1372
Markus
>> > [1] https://github.com/OSGeo/grass/commits/master
