[GRASS-dev] Docker builds
Vaclav Petras wenzeslaus at gmail.com
Thu Feb 18 15:22:47 PST 2021
On Thu, Feb 18, 2021 at 4:09 PM Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Feb 18, 2021 at 9:15 PM Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > Dear all,
> > Docker build which runs on each commit in master branch on
> hub.docker.com fails.
> I don't see any failures in hub.docker.com under our (mundialis) account.
> I just see a long queue of builds in the pipeline due to the high
> amount of commits in the last few hours.
> > I'm not managing these builds,
> Do you refer to the builds made my mundialis? Carmen and I take care.
I guess so. I refer to those which you can see in commits on master branch.
See attached.
> Unfortunately the link under the red X in [1] is broken: 404.
That's what I get, but I thought it is something you need to log into first
to see that.
> > so I see only that something starting with ci/dockercloud-stage
> (/docker/alpine/Dockerfile_` fails in the.
> > The ones which are substantially different from what we test on GitHub
> should be tested there for each PR using GH workflow. On the other hand, if
> there is no way of fixing it and/or no need for them, the best course of
> action is to remove them. Each commit on master branch now shows as a
> failure [1].
> > Vaclav
> > [1] https://github.com/OSGeo/grass/commits/master
> Maybe simply too many commits (which is great!!) in short time and
> docker quota exceeded for today?
The first ones failing are already on Feb 12.
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210218/33be5b01/attachment-0001.html>
Name: Screenshot from 2021-02-18 18-21-34.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210218/33be5b01/attachment-0001.png>
