[GRASS-dev] Docker builds
Markus Neteler
neteler at osgeo.org
Thu Feb 18 13:09:18 PST 2021
On Thu, Feb 18, 2021 at 9:15 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Dear all,
> Docker build which runs on each commit in master branch on hub.docker.com fails.
I don't see any failures in hub.docker.com under our (mundialis) account.
I just see a long queue of builds in the pipeline due to the high
amount of commits in the last few hours.
> I'm not managing these builds,
Do you refer to the builds made my mundialis? Carmen and I take care.
Unfortunately the link under the red X in [1] is broken: 404.
> so I see only that something starting with ci/dockercloud-stage (/docker/alpine/Dockerfile_` fails in the.
> The ones which are substantially different from what we test on GitHub should be tested there for each PR using GH workflow. On the other hand, if there is no way of fixing it and/or no need for them, the best course of action is to remove them. Each commit on master branch now shows as a failure [1].
> Vaclav
> [1] https://github.com/OSGeo/grass/commits/master
Maybe simply too many commits (which is great!!) in short time and
docker quota exceeded for today?
Markus
