[GRASS-dev] r.stats.quantile: does the 50th percentile equal to the median?
Markus Metz
markus.metz.giswork at gmail.com
Sat Jan 23 12:20:59 PST 2021
On Fri, Jan 22, 2021 at 2:51 PM <nik at nikosalexandris.net> wrote:
> Hi devs,
> does the default `percentiles=50` in `r.stats.quantile` equal to the
> median?
> Is the definition exclusive or inclusive?
The median is commonly defined as the 50% percentile, the "middle" item of
a sorted dataset. See
https://en.wikipedia.org/wiki/Median
In GRASS, calculations of the median and the 50% percentile are identical.
HTH,
Markus M
> Thank you for any insight, Nikos
> See also
> - https://en.wikipedia.org/wiki/Percentile
> - https://math.stackexchange.com/q/2048470/445399
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210123/871eba69/attachment.html>
