[GRASS-dev] r.stats.quantile: does the 50th percentile equal to the median?
nik at nikosalexandris.net
Sat Jan 23 18:22:34 PST 2021
Thank you Markus!
On 2021-01-23 21:20, Markus Metz wrote:
> On Fri, Jan 22, 2021 at 2:51 PM <nik at nikosalexandris.net> wrote:
>> Hi devs,
>> does the default `percentiles=50` in `r.stats.quantile` equal to the
>> median?
>> Is the definition exclusive or inclusive?
> The median is commonly defined as the 50% percentile, the "middle" item of a sorted dataset. See
> https://en.wikipedia.org/wiki/Median
> In GRASS, calculations of the median and the 50% percentile are identical.
> HTH,
> Markus M
>> Thank you for any insight, Nikos
>> See also
>> - https://en.wikipedia.org/wiki/Percentile
>> - https://math.stackexchange.com/q/2048470/445399
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210124/fb454679/attachment.html>
