[GRASS-dev] [release planning] GRASS GIS 8: create new release branch
Maris Nartiss maris.gis at gmail.com
Sat Jul 10 01:19:55 PDT 2021
Hello all.
2021-07-09 21:39 GMT+03:00, Markus Neteler <neteler at osgeo.org>:
> Hi Anna, all,
> So, from my point of view, as you suggest:
> - get g.extension working, then
> - create a new release branch
> - after that the GSoC merge into master.
There are a few PRs to merge but they are stuck due to failing tests –
Windows build & test is just bad (no bug or PR so far?), CentOS is too
old (#1709) & needs auto tools update to fix it (or at least env
variable in build script as I just have done to enable testing in
#1501), Ubuntu based test scripts use g.download.location extension
that is not operational at the moment (fixed by #1715?).
I would also strongly advocate merging ctypes upgrade before 8.0
> Best,
> Markus
Māris.
