[GRASS-dev] [release planning] GRASS GIS 8: create new release branch
Vaclav Petras wenzeslaus at gmail.com
Wed Jul 14 14:24:58 PDT 2021
On Sat, Jul 10, 2021 at 4:20 AM Maris Nartiss <maris.gis at gmail.com> wrote:
> Hello all.
> 2021-07-09 21:39 GMT+03:00, Markus Neteler <neteler at osgeo.org>:
> > Hi Anna, all,
> > So, from my point of view, as you suggest:
> > - get g.extension working, then
#1700 seems to be close to being finished. Please test.
https://github.com/OSGeo/grass/pull/1700
> There are a few PRs to merge but they are stuck due to failing tests –
I fixed the g.download.location part in #1715 and all or most "randomly"
failing tests in #1681.
https://github.com/OSGeo/grass/pull/1681
> Windows build & test is just bad (no bug or PR so far?),
Can someone give an update on that, please?
> CentOS is too
> old (#1709) & needs auto tools update to fix it (or at least env
> variable in build script as I just have done to enable testing in
> #1501),
...or CentOS 8, CentOS Stream, or remove the CentOS test.
https://github.com/OSGeo/grass/issues/1709#issuecomment-880215427
> Ubuntu based test scripts use g.download.location extension
> that is not operational at the moment (fixed by #1715?).
#1715 is merged, so the tests are fixed.
> I would also strongly advocate merging ctypes upgrade before 8.0
Seems to be close to being finished too.
Vaclav
> > Best,
> > Markus
> Māris.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210714/fba43479/attachment.html>
