[GRASS-dev] Switching default branch for grass-addons to grass7
Vaclav Petras
wenzeslaus at gmail.com
Tue Jul 13 10:19:48 PDT 2021
On Sun, Jul 4, 2021 at 3:49 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Not directly related to the changes, but the build and test workflow is
> currently disabled by GitHub because GitHub thinks the OSGeo/grass-addons
> repo is a fork. I could enable it manually, but instead, I contacted GitHub
> support in order to resolve the situation correctly.
The message from GitHub support said that thier engineering team confirmed
this is a bug and will fix it and that we should enable the workflow
manually now which is what I just did.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210713/fe85751e/attachment.html>
