[GRASS-dev] function to get mouse position - too vague
Zoltan
zoltans at geograph.co.za
Thu Jul 22 04:37:01 PDT 2021
Hi again,
OK, I was far to vague.......
What I am looking for is where in the digitising functions the
mouse-clicks are collected to add/edit/etc the geometry elements.
I'm scratching through the 'C' progs and .py folders ..........but some
guidance would shorten my quest.
Thanks and keep well,
Zoltan
On 2021/07/21 17:07, Zoltan wrote:
> Hi Devs,
> Is there a function that will return the coordinates of the mouse
> pointer, if it is inside a graphics window?
> This on mouse-click.
> Ideally the return value would be: button,x,y(,z)
> Even more ideally, if mouse hovers inside a graphics window, and a
> keyboard key is press (say the letter 'k'), then the return value
> would be "k,x,y(,z)"
> If any of you are old enough to have used Genamap, then I am looking
> to emulate its 'gloc' command.
> TIA,
> Zoltan
Zoltan Szecsei GPrGISc 0031
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
Cape Town, South Africa.
Mobile: +27-83-6004028 (Signal, not WhatsApp)
www.geograph.co.za
