[GRASS-dev] SOLVED: Re: function to get mouse position - too vague
Zoltan zoltans at geograph.co.za
Thu Jul 22 06:54:33 PDT 2021
Apologies for the bandwidth taken - I should have though of this earlier:
grep -i -R --include "*.py" "mouse"
and
grep -i -R --include "*.c" "mouse"
Regards,
Zoltan
On 2021/07/22 13:37, Zoltan wrote:
> Hi again,
> OK, I was far to vague.......
> What I am looking for is where in the digitising functions the
> mouse-clicks are collected to add/edit/etc the geometry elements.
> I'm scratching through the 'C' progs and .py folders ..........but
> some guidance would shorten my quest.
> Thanks and keep well,
> Zoltan
> On 2021/07/21 17:07, Zoltan wrote:
>> Hi Devs,
>> Is there a function that will return the coordinates of the mouse
>> pointer, if it is inside a graphics window?
>> This on mouse-click.
>> Ideally the return value would be:   button,x,y(,z)
>> Even more ideally, if mouse hovers inside a graphics window, and a
>> keyboard key is press (say the letter 'k'), then the return value
>> would be "k,x,y(,z)"
>> If any of you are old enough to have used Genamap, then I am looking
>> to emulate its 'gloc' command.
>> TIA,
>> Zoltan
Zoltan Szecsei GPrGISc 0031
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
Cape Town, South Africa.
Mobile: +27-83-6004028 (Signal, not WhatsApp)
www.geograph.co.za
