[GRASS-dev] FIXED: Re: compiling GRASS-latest - configure fails with Unable to locate PostgreSQL includes
Zoltan
zoltans at geograph.co.za
Mon Jun 21 07:08:59 PDT 2021
Hi Markus,
OK, I am now logged into the Ubuntu system I used, and can better trace
what I did.
I started my research at
https://github.com/OSGeo/grass/blob/previewbranch_8_0/INSTALL
Under "Prerequisite/Installation order" I installed/compiled gdal with
ecw, and installed postgres.
I then did a ./configure (without extra parameters) and tried to bumble
my way through the errors I was getting.
I fired off my initial email to grass-dev as I was not finding the solution.
I then found the grass-wiki recipe and corrected the problems by
copy/paste the ./configure for Ubuntu 20.04
So, a few thoughts from my side.
* In the github install (all versions of grass), add a pointer to the
grasswiki page, especially at the ./configure paragraph. (I would
find it more reliable and easy to manage a link to one source of
info, than to copy the source into contents of other documents)
* Amend the configure script error message to suggest the that the
with-XXX-includes= parameter should be used, instead of just:
configure: error: *** Unable to locate FreeType includes.
* As most apt installed products go to specific directories, is it
possible to let the configure script not first try a few obvious
places before crashing with the error message? If they are not 'apt
installed', then they likely go to /usr/*local/*XXX
HTH, and thanks again for your persistence.
Regards,
Zoltan
On 2021/06/21 13:32, Markus Neteler wrote:
> Hi Zoltan,
> Where would you expect this info, i.e. a link to the wiki?
> Maybe we can improve things :)
> Best
> Markus
> Zoltan <zoltans at geograph.co.za <mailto:zoltans at geograph.co.za>>
> schrieb am Mo., 21. Juni 2021, 12:11:
> Hi Markus/Māris,
> Thanks for your interest.
> @Māris: I did provide the log tail-end on my first post.
> @Markus: I started off the process using Google/Duck-Duck-Go to
> piece together what info I needed, as I wanted ECW support and one
> or two other add-ons.
> Far too many websites offering help, come up.
> I read through a couple but only later the Grasswiki you referred
> to below - and then only noticing the with-XXX-includes folder
> directives.
> my bad :-(
> Regards and keep well,
> Zoltan
> *On 2021-06-21 07:20, Maris Nartiss wrote:*
>> Please include relevant part of configure.log where exact reasons of
>> failure will be seen.
>> Māris.
> *On 2021-06-20 18:42, Markus Neteler wrote:*
>> Hi Zoltan,
>> On Sat, Jun 19, 2021 at 12:36 PM Zoltan<zoltans at geograph.co.za> <mailto:zoltans at geograph.co.za> wrote:
>>> Hi Devs,
>>> Sorted!
>>> The correct folder(s) were: -with-postgres-includes=/usr/include/postgresql --with-freetype-includes=/usr/include/freetype2
>>> (Had to add the freetype include folder as well)
>> Glad you solved it.
>> BTW, there is a wiki page with hints:
>> https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Quick_instructions <https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Quick_instructions>
>> Please feel free to improve it as needed.
>> Best
>> Markus
> Zoltan Szecsei GPrGISc 0031
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> Cape Town, South Africa.
> Mobile: +27-83-6004028 (Signal, not WhatsApp)
> www.geograph.co.za <http://www.geograph.co.za>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210621/1524efff/attachment.html>
