[GRASS-dev] libgrass_gis.7.8 not found issue
Pedro Venâncio pedrongvenancio at gmail.com
Wed Mar 3 06:28:00 PST 2021
Hi all,
I've installed GRASS 7.8.5 from new OSGeo4W installer [0], but when I run
GRASS and try to start a new session I get:
Cleaning up temporary files...
D1/1: G_set_program_name(): clean_temp
D1/1: G_set_program_name(): db.connect
D1/1: Creating new default DB params with db_set_default_connection()
          __________  ___   __________    _______________
         / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
        / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
       / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
       \____/_/ |_/_/  |_/____/____/   \____/___//____/
Welcome to GRASS GIS 7.8.5
GRASS GIS homepage:                      https://grass.osgeo.org
This version running through:            Command Prompt
(C:\WINDOWS\system32\cmd.exe)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
See citation options with:               g.version -x
If required, restart the GUI with:       g.gui wxpython
When ready to quit enter:                exit
Launching <wxpython> GUI in the background, please wait...
Microsoft Windows [Version 10.0.19042.804]
(c) 2020 Microsoft Corporation. Todos os direitos reservados.
C:\OSGeo4W64\bin>D1/1: G_set_program_name(): g.gisenv
D1/1: grass.script.core.start_command(): g.gisenv -n
wxnviz.py: Could not find module
'C:\OSGEO4~1\apps\grass\grass78\lib\libgrass_gis.7.8.dll' (or one of
its dependencies). Try using the full path with constructor syntax.
wxdigit.py: Could not find module
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\wxgui.py", line
104, in OnInit
    from lmgr.frame import GMFrame
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\lmgr\frame.py",
line 51, in <module>
    from lmgr.layertree import LayerTree, LMIcons
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\lmgr\layertree.py",
line 38, in <module>
    from mapdisp.frame import MapFrame
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\mapdisp\frame.py",
line 43, in <module>
    from mapwin.buffered import BufferedMapWindow
  File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\mapwin\buffered.py",
line 52, in <module>
    import grass.lib.gis as gislib
  File "C:\OSGEO4~1\apps\grass\grass78\etc\python\grass\lib\gis.py",
line 23, in <module>
    _libs["grass_gis.7.8"] = load_library("grass_gis.7.8")
  File "C:\OSGEO4~1\apps\grass\grass78\etc\python\grass\lib\ctypes_loader.py",
line 62, in load_library
    return self.load(path)
line 240, in load
    return _WindowsLibrary(path)
line 223, in __init__
    self.cdll = ctypes.cdll.LoadLibrary(path)
  File "C:\OSGEO4~1\apps\Python39\lib\ctypes\__init__.py", line 452,
in LoadLibrary
    return self._dlltype(name)
  File "C:\OSGEO4~1\apps\Python39\lib\ctypes\__init__.py", line 374, in __init__
    self._handle = _dlopen(self._name, mode)
FileNotFoundError: Could not find module
OnInit returned false, exiting...
This seems to affect Windows 10 operating systems in locale languages,
in this case, portuguese, where the issue is confirmed on 3 different
machines.
I've reported it in OSGeo4W tracker [1], because I thought it was
related to some kind of packaging issue, but I decided to post it here
to get your opinions.
Thank you very much.
Best regards,
Pedro Venâncio
[0] https://download.osgeo.org/osgeo4w/testing/
[1] https://trac.osgeo.org/osgeo4w/ticket/661
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210303/f4c3d891/attachment.html>
