[GRASS-dev] GRASS GIS ready for PROJ 7?
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Sat Mar 6 01:40:03 PST 2021
To underpin Jürgens point:
In my company we used "creatensis.pl" to create custom OSGeo4W installations with modified startup scripts (so users get prepared configurations.
That worked quite well. Doing so for a "GRASS GIS standalone" installer might reduce maintenance, risk of bugs and confusion among users. So, I would definitely recommend to follow Jürgens suggestion.
Cheers
Stefan
-----Original Message-----
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Jürgen E. Fischer
Sent: fredag 5. mars 2021 20:53
To: grass-dev at lists.osgeo.org
Subject: Re: [GRASS-dev] GRASS GIS ready for PROJ 7?
Hi Helmut,
On Fri, 05. Mar 2021 at 20:11:03 +0100, Helmut Kudrnovsky wrote:
> in OSGeo4W actually:
> C:\>proj --version
> Rel. 6.3.2, May 1st, 2020
> OSGeo4W next generation is in a testing phase at the moment.
> one of the biggest steps forward is:
> >PROJ 7.2 <=
Meanwhile PROJ 8.
> * including more than 500MB data into our standalone installer may explode
> our used NSIS system.
The standalone installer of QGIS is directly based on OSGeo4W packages. It just starts off with the qgis-full package and includes all it's dependencies and hence also includes GRASS.
The packages are fetched and extracted and packed up again for the installer, which later runs extracts them on and runs the included postinstall scripts
of the OSGeo4W packages on the target machine.
Except for selecting the target directory and setting whether desktop and/or start menu shortcuts should be created, there is currently no way to add more configuration.
The same approach, but starting off with grass instead of qgis-full could also work for GRASS.
And creatensis.pl was ported to MSI as createmsi.pl - because it now uses the Microsoft Installer instead of NSIS to work around NSIS' 2GB limit.
The experimental MSI installer also includes GRASS (although not the latest updates of OSGeo4W regarding os.add_dll_directory necessary for Python 3.9).
See also https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fpipermail%2Fqgis-user%2F2021-February%2F048137.html&data=04%7C01%7C%7Cde782249b1d94ada482a08d8e01057d8%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637505708089015542%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=Y4%2FZboGT5QD975HderBYUfAB7Wqd6QRzPP%2B5u9KXsXY%3D&reserved=0
and https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fpipermail%2Fqgis-user%2F2021-February%2F048199.html&data=04%7C01%7C%7Cde782249b1d94ada482a08d8e01057d8%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637505708089015542%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=E2lHIE3HX0yMrmIPTZ%2BymZhoczVZ6LlOQsJ8MfqlC%2FQ%3D&reserved=0.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.norbit.de%2F&data=04%7C01%7C%7Cde782249b1d94ada482a08d8e01057d8%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637505708089015542%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=FkW2HofwNj2Q7wCM19g9SWEc9LS4tO%2FcJT5VadfXwto%3D&reserved=0
QGIS release manager (PSC) Germany IRC: jef on FreeNode
