[GRASS-dev] [GRASS GIS] #2895: Define dependencies for GRASS addons
trac at osgeo.org
Fri Mar 12 20:06:13 PST 2021
Reporter: pmav99 | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.8.3
Component: Default | Version: unspecified
Resolution: | Keywords: g.extension
CPU: Unspecified | Platform: Unspecified
Comment (by wenzeslaus):
Replying to [comment:23 sbl]:
> I just added a draft for a python script that could take care of
dependencies in Python (conda not tested) and R packages. Other
dependencies (e.g. C-libraries, commandline tools) are just checked,
neither loading of the libraries not installation is supported at the
moment (not sure if the latter is realistic).
The current code looks straightforward and perhaps worth trying it in
action (you can make an addon module which installs dependencies and then
runs g.extension on the actual module).
However, I think this can also get really complex. What about turning this
the other way around and focusing supporting GRASS modules which are
Python packages installed with conda or pip like itzi? They would just use
the existing systems for dependencies. Still, g.extension could use
handle_dependencies.py logic, but it would use it to install the module
rather than the dependencies.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2895#comment:25>
