[GRASS-dev] Fwd: [Bug] Fix currently ignored Flake8 warnings #1522
Shubham Swati Prasad h20200049 at goa.bits-pilani.ac.in
Fri May 7 10:11:04 PDT 2021
Respected sir/madam
I have compiled the code now. Can I start working on the issue now? Or is
there something else I need to configure before I start working on it?
Kindly guide me.
Regards
Shubham Swati
On Fri, May 7, 2021 at 10:31 PM Markus Neteler <neteler at osgeo.org> wrote:
> You wrote to grass-dev before. Please continue with that.
> Regards
> Shubham Swati Prasad <h20200049 at goa.bits-pilani.ac.in> schrieb am Fr., 7.
> Mai 2021, 18:46:
>> I beg your pardon, but which list I have to write in to? Does it mean
>> that I can start working on the issue? Can you explain please.
>> On Fri, May 7, 2021 at 10:09 PM Markus Neteler <neteler at osgeo.org> wrote:
>>> Great. Please write to the list, thanks.
>>> 7. Mai 2021, 18:38:
>>>> Sir, thanks for sharing the above link. I have finished the compilation
>>>> process. Now can I start working on the issue or are there more things to
>>>> configure before I start working on it? Kindly guide.
>>>> Regards
>>>> Shubham Swati
>>>> On Fri, May 7, 2021 at 1:16 AM Markus Neteler <neteler at osgeo.org>
>>>> wrote:
>>>>> Hi,
>>>>> On Thu, May 6, 2021 at 5:47 PM Shubham Swati Prasad
>>>>> <h20200049 at goa.bits-pilani.ac.in> wrote:
>>>>> > Respected sir,
>>>>> > I have cloned the repository and after that I'm totally stuck. I
>>>>> don't know how to proceed further. I want to start working on the bug as
>>>>> soon as possible. Kindly guide me.
>>>>> Since you have Ubuntu, please follow the instructions here:
>>>>> https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Quick_instructions
>>>>> Best,
>>>>> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210507/cca51431/attachment.html>
