[GRASS-dev] Fwd: [Bug] Fix currently ignored Flake8 warnings #1522
Vaclav Petras
wenzeslaus at gmail.com
Fri May 7 20:35:54 PDT 2021
Hi Shubham Swati,
Assuming you are working on that Ubuntu machine, make sure you have python3
and pip3. Then, install black and flake8 with pip3 (just search for this
sentence online if pip is new to you). That is all tools you need.
(Definitely check what black and esp. flake8 commands do if this is your
first time seeing them. And of course, there is at least one text editor on
Ubuntu by default - gedit. You can just open any text file including .py
files there.
Then you need to just start. Sift through the issues, pick a random one or
whatever approach works for you. Remember that if it would be trivial it
would be fixed already, so don't be surprised when you will need to spend
some time searching (online and in the code base) and experimenting (with
the code or standalone examples).
You are certainly welcome to work on any issue any time, but a nice setup
makes success more likely. Good luck!
Vaclav
On Fri, May 7, 2021 at 1:11 PM Shubham Swati Prasad <
h20200049 at goa.bits-pilani.ac.in> wrote:
> Respected sir/madam
> I have compiled the code now. Can I start working on the issue now? Or is
> there something else I need to configure before I start working on it?
> Kindly guide me.
> Regards
> Shubham Swati
> On Fri, May 7, 2021 at 10:31 PM Markus Neteler <neteler at osgeo.org> wrote:
>> You wrote to grass-dev before. Please continue with that.
>> Regards
>> Shubham Swati Prasad <h20200049 at goa.bits-pilani.ac.in> schrieb am Fr.,
>> 7. Mai 2021, 18:46:
>>> I beg your pardon, but which list I have to write in to? Does it mean
>>> that I can start working on the issue? Can you explain please.
>>> On Fri, May 7, 2021 at 10:09 PM Markus Neteler <neteler at osgeo.org>
>>> wrote:
>>>> Great. Please write to the list, thanks.
>>>> 7. Mai 2021, 18:38:
>>>>> Sir, thanks for sharing the above link. I have finished the
>>>>> compilation process. Now can I start working on the issue or are there more
>>>>> things to configure before I start working on it? Kindly guide.
>>>>> Regards
>>>>> Shubham Swati
>>>>> On Fri, May 7, 2021 at 1:16 AM Markus Neteler <neteler at osgeo.org>
>>>>> wrote:
>>>>>> Hi,
>>>>>> On Thu, May 6, 2021 at 5:47 PM Shubham Swati Prasad
>>>>>> <h20200049 at goa.bits-pilani.ac.in> wrote:
>>>>>> > Respected sir,
>>>>>> > I have cloned the repository and after that I'm totally stuck. I
>>>>>> don't know how to proceed further. I want to start working on the bug as
>>>>>> soon as possible. Kindly guide me.
>>>>>> Since you have Ubuntu, please follow the instructions here:
>>>>>> https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Quick_instructions
>>>>>> Best,
>>>>>> Markus
>>>>> _______________________________________________
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210507/462e4cea/attachment.html>
