[GRASS-dev] r.clump on floating map
Markus Metz markus.metz.giswork at gmail.com
Fri May 21 14:00:20 PDT 2021
Hi Paulo,
r.clump currently converts a floating point raster to integer, this could
explain the rather large clusters consisting of raster cells that do not
have the same values.That is easy to fix, please create a corresponding
issue on github as a reminder.
Cheers,
Markus M
On Wed, May 19, 2021 at 6:18 PM Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> Hi devs,
> How is r.clump suppose to handle floating rasters? I ran the function on a
> floating raster, and threshold value set to 0 (default). The values
> represent gradually changing values. Yet, it returned a map with rather
> large clusters consisting of raster cells that do not have the same values.
> Cheers,
> Paulo
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210521/15004ffb/attachment.html>
