[GRASS-dev] ParallelModuleQueue freezes...
Luca Delucchi lucadeluge at gmail.com
Wed May 26 21:07:09 PDT 2021
On Thu, 27 May 2021 at 04:07, Anna Petrášová <kratochanna at gmail.com> wrote:
> Could you provide an example that is failing? The doctests are running for me. I spent some time fixing it a couple months ago. I use Python 3.6, I wonder if newer Python would cause some issues.
https://github.com/OSGeo/grass-addons/pull/523/files line 544, the
commented lines are not working for me..
If you want to try t.vi just comment line 543 and uncomment the
following lines..
> Anna
ciao
Luca
www.lucadelu.org
