[GRASS-dev] ParallelModuleQueue freezes...
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Wed May 26 23:19:07 PDT 2021
The combination ParallelModuleQueue and MultiModule is used in t.rast.neighbors: https://github.com/OSGeo/grass/blob/master/temporal/t.rast.neighbors/t.rast.neighbors.py
The testsuite of that module is deactivated for Python > 2.
https://github.com/OSGeo/grass/blob/master/temporal/t.rast.neighbors/testsuite/test_neighbors.py
If you activate it by commenting out line 15. You will see the behavior...
Thanks for looking into this!
Cheers
Stefan
-----Original Message-----
Sent: torsdag 27. mai 2021 06:07
To: Anna Petrášová <kratochanna at gmail.com>
Cc: Stefan Blumentrath <Stefan.Blumentrath at nina.no>; GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] ParallelModuleQueue freezes...
On Thu, 27 May 2021 at 04:07, Anna Petrášová <kratochanna at gmail.com> wrote:
> Could you provide an example that is failing? The doctests are running for me. I spent some time fixing it a couple months ago. I use Python 3.6, I wonder if newer Python would cause some issues.
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FOSGeo%2Fgrass-addons%2Fpull%2F523%2Ffiles&data=04%7C01%7C%7Cb35d171402fc441dfd7508d920c4edc3%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637576852445926368%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=a8JVAn3N77HwODX5FguDQjxI4PbUbkN4ZicO4RYuHqo%3D&reserved=0 line 544, the commented lines are not working for me..
If you want to try t.vi just comment line 543 and uncomment the following lines..
> Anna
ciao
Luca
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.lucadelu.org%2F&data=04%7C01%7C%7Cb35d171402fc441dfd7508d920c4edc3%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637576852445936369%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=RWkoI4e%2BbY9%2F5Ow%2BOMqPtEgHGS2BqWRL4pes%2B%2B5T%2BNA%3D&reserved=0
