[GRASS-dev] addon r.area.createweight not available?
Stefan Blumentrath Stefan.Blumentrath at nina.no
Tue Oct 19 01:49:08 PDT 2021
Hi again,
There were actually also some issues with the manual HTML. Tried to fix them in the same PR, and wit the changes in place the addon should install. I did not go through how the manual looks now. So, Charlotte, please test and review before I merge!
Cheers
Stefan
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Stefan Blumentrath
Sent: tirsdag 19. oktober 2021 09:45
To: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] addon r.area.createweight not available?
See: https://github.com/OSGeo/grass-addons/pull/626
From: grass-dev <grass-dev-bounces at lists.osgeo.org<mailto:grass-dev-bounces at lists.osgeo.org>> On Behalf Of Stefan Blumentrath
Sent: tirsdag 19. oktober 2021 09:40
To: GRASS developers list <grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>>
Hi Charlotte,
It seems, the issue is that the Makefile is named 'Makefile.txt'.
So it is not executed and the addon is not built.
If you rename it, the addon should become available with the next (nightly) build...
Cheers
Stefan
From: grass-dev <grass-dev-bounces at lists.osgeo.org<mailto:grass-dev-bounces at lists.osgeo.org>> On Behalf Of FLASSE Charlotte via grass-dev
Sent: tirsdag 19. oktober 2021 09:21
To: grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>
Subject: [GRASS-dev] addon r.area.createweight not available?
Dear all,
I was expecting the add-on r.area.createweight to be included with the 7.8.6 release of GRASS, but it does not appear either in the 'new addons' list on the summary of changes<https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Ftrac.osgeo.org%2Fgrass%2Fwiki%2FRelease%2F7.8.6-News&data=04%7C01%7CStefan.Blumentrath%40nina.no%7Ccdeff4d1bd944a7927a808d992d45fce%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637702263109351673%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=9oGSilYPWAgRJ8PKauMKZLHWqAfLX9bzte%2Bx3zzRc2A%3D&reserved=0> page, nor is it possible to add with g.extension.
Was wondering what the issue might be ?
Thanks,
Charlotte
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20211019/36d58f35/attachment.html>
