[GRASS-dev] Renaming master branch to main branch
Markus Metz markus.metz.giswork at gmail.com
Fri Sep 10 10:15:55 PDT 2021
Probably a silly question:
I'm having problems with rebasing my local feature branches for PRs, e.g.
for https://github.com/OSGeo/grass/pull/1786
My local main branch is up to date with the official main branch. In my
case the grass repo is the remote named origin, my fork is the remote named
metzm
$ git checkout raster_tempdir
$ git rebase main
Successfully rebased and updated refs/heads/raster_tempdir.
$ git status
On branch raster_tempdir
Your branch and 'metzm/raster_tempdir' have diverged,
and have 48 and 7 different commits each, respectively.
  (use "git pull" to merge the remote branch into yours)
$ git push metzm raster_tempdir
! [rejected]            raster_tempdir -> raster_tempdir (non-fast-forward)
error: failed to push some refs to 'github.com:metzm/grass.git'
hint: Updates were rejected because the tip of your current branch is behind
hint: its remote counterpart. Integrate the remote changes (e.g.
hint: 'git pull ...') before pushing again.
hint: See the 'Note about fast-forwards' in 'git push --help' for details.
Any hints on how to proceed from here without messing up the history of my
feature branch? Thanks!
Markus M
On Sun, Aug 22, 2021 at 9:26 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Dear all,
> The master branch was renamed to main. Please update your local
> repositories and workflows accordingly.
> ## 1. Local repo update and branch rename
> If you are contributing code or compiling source code from Git, you need
> to modify your local repository as well. Go to your fork's website on
> GitHub. It will warn you about the rename in the OSGeo repo. Go to settings
> and to the rename. Go to the main page of your fork again. Now it will warn
> you about the rename in your repo (your fork). It will give you
> instructions on renaming the local branch and making it point to the
> renamed branch. (The assumption is that your fork repo is the remote named
> origin.)
> Additionally, there still will be upstream/master and you can remove it
> using (assuming upstream remote is the OSGeo repo. You can remove
> upstream/master and update info about the default branch using:
> git fetch upstream --prune
> git remote set-head upstream -a
> Alternatively, if you are not keeping your fork's master/main branch up to
> date, you can follow instructions from my initial email which allow you to
> skip the fork part resulting in a slightly different local setup.
> ## 2. Updating your contributing steps
> To update your local main branch (base branch) and to rebase or merge with
> the latest source code, use upstream/main instead of upstream/master.
> ## 3. Updating workflows using source code from Git
> If you have a workflow which is using the source code obtained from Git ,
> you will need to update it if you explicitly specify the branch name. If
> you do --branch, checkout, or switch, and at the same time using the master
> branch, you will need to change "master" to "main". If you use only a
> simple `git clone`, no changes are needed because `git clone` takes the
> default branch which will continue to work.
> ## 4. Other issues
> The base branch for PRs was changed automatically. The PRs updating most
> of the source code for core and addons were merged. Some CI-related changes
> will still be needed for core. Additionally, I assume the workflows outside
> of the source code will be updated as part of the updates to addons repo
> structure and changes for the release branch for 8.0. Help in this area is
> welcome.
> https://github.com/OSGeo/grass/pull/1806
> https://github.com/OSGeo/grass-addons/pull/598
> Let me know if you face any questions.
> Best,
> Vaclav
> On Wed, Aug 18, 2021 at 10:41 PM Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
>> Dear all,
>> I will rename our default branch currently called master to main in the
>> following days. We already discussed it here and there, but the rename
>> should be relatively smooth. Much simpler than the addons repo
>> reorganization. Users not compiling code themselves should not be affected.
>> Contributors will be, but GitHub warns you about the rename when you come
>> to the repo web page. Those compiling from source may need to make changes.
>> The update of a local clone can be done with instructions similar to the
>> following (I will post them again once I confirm it is the best fit):
>> git branch -m master main
>> git fetch upstream
>> git branch -u upstream/main main
>> Additionally, to get rid of upstream/master, do:
>> git fetch --prune
>> You don't need to update your fork unless you want to.
>> The changes needed in the repo are already in a PR (feel free to review):
>> Those compiling from source code obtained from Git will need to make
>> changes when they explicitly specify the branch. A simple `git clone` takes
>> the default branch which will continue to work. However, if you do
>> Let me know if you have any questions or concerns.
>> Best,
>> Vaclav
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210910/c3671862/attachment.html>
