[GRASS-dev] Renaming master branch to main branch
Vaclav Petras wenzeslaus at gmail.com
Fri Sep 10 11:45:46 PDT 2021
On Fri, Sep 10, 2021 at 2:30 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> The commit history of the PR has not been messed up, only the relevant
> commits are shown.
Right, right, Git or GitHub recognizes that thoise 41 are already on main.
The reason for the rebase was that some tests were failing, apparently
> because of a combination of renaming master to main and changes to GHA, and
> a PR can only be squashed and merged if all tests are passed.
Ah, that makes sense. You need to update in one way or another in this case.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210910/5619a8d0/attachment.html>
