[GRASS-dev] Renaming master branch to main branch
Markus Metz
markus.metz.giswork at gmail.com
Fri Sep 10 13:36:36 PDT 2021
On Fri, Sep 10, 2021 at 8:46 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Fri, Sep 10, 2021 at 2:30 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
>> The reason for the rebase was that some tests were failing, apparently
because of a combination of renaming master to main and changes to GHA, and
a PR can only be squashed and merged if all tests are passed.
> Ah, that makes sense. You need to update in one way or another in this
case.
After `git rebase main` + `git push -f ...`, all the previously timed-out
tests for the affected PRs are passed, great!
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210910/54e756c0/attachment.html>
