[GRASS-dev] [release planning] GRASS GIS 7.8.8
Markus Neteler
neteler at osgeo.org
Fri May 13 04:08:35 PDT 2022
Hi devs,
Here the milestone:
https://github.com/OSGeo/grass/milestone/14?closed=1
it lists the following fix:
--> Make: add -rpath to LD_SEARCH_FLAGS #2280
which is relevant for the GDAL-GRASS driver, to avoid /etc/ldconfig.d/ tricks.
BTW, this driver has been moved to a separate repo, for easier
maintenance and less burden to GDAL devs:
https://github.com/OSGeo/gdal-grass/
Hence I would suggest that I create 7.8.8RC1.
Any objections?
Best,
Markus
