[GRASS-dev] [release planning] GRASS GIS 7.8.8
Veronica Andreo veroandreo at gmail.com
Fri May 13 05:56:54 PDT 2022
El vie, 13 may 2022 a las 13:09, Markus Neteler (<neteler at osgeo.org>)
escribió:
> Hi devs,
> Here the milestone:
> https://github.com/OSGeo/grass/milestone/14?closed=1
> it lists the following fix:
> --> Make: add -rpath to LD_SEARCH_FLAGS #2280
> which is relevant for the GDAL-GRASS driver, to avoid /etc/ldconfig.d/
> tricks.
> BTW, this driver has been moved to a separate repo, for easier
> maintenance and less burden to GDAL devs:
> https://github.com/OSGeo/gdal-grass/
> Hence I would suggest that I create 7.8.8RC1.
> Any objections?
No objection from my side
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220513/6ad1e905/attachment.htm>
