[GRASS-dev] [release planning] GRASS GIS 7.8.8
Markus Neteler
neteler at osgeo.org
Sat May 14 02:39:24 PDT 2022
On Fri, May 13, 2022 at 2:57 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> El vie, 13 may 2022 a las 13:09, Markus Neteler (<neteler at osgeo.org>) escribió:
>> Hi devs,
>> Here the milestone:
>> https://github.com/OSGeo/grass/milestone/14?closed=1
>> it lists the following fix:
>> --> Make: add -rpath to LD_SEARCH_FLAGS #2280
>> which is relevant for the GDAL-GRASS driver, to avoid /etc/ldconfig.d/ tricks.
>> BTW, this driver has been moved to a separate repo, for easier
>> maintenance and less burden to GDAL devs:
>> https://github.com/OSGeo/gdal-grass/
>> Hence I would suggest that I create 7.8.8RC1.
>> Any objections?
> No objection from my side
GRASS GIS 7.8.8RC1 is available:
https://github.com/OSGeo/grass/releases/tag/7.8.8RC1
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
