[GRASS-dev] hacktober, docs
Daniel Torres
nobeeakon at gmail.com
Fri Oct 7 12:05:26 PDT 2022
What about something like
[image: imagen.png]
It is just to have something to show, any suggestion and improvement is
welcomed. Otherwise, if you think is ok let me know to do the PR
On Fri, Oct 7, 2022 at 9:12 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Fri, 7 Oct 2022 at 09:18, Daniel Torres <nobeeakon at gmail.com> wrote:
>> I see that all issues tagged with 'Hacktober' are coding related, do you
>> guys have any idea of non coding stuff that could work? like first-issue
>> but non coding? mmm I don't know, documentation, missing examples, and so
>> on?
> Images for documentation are often missing, e.g.:
> https://grass.osgeo.org/grass82/manuals/raster_graphical.html
> (Often it is enough to use the existing example to generate the image.)
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20221007/3ff48046/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20221007/3ff48046/attachment-0001.png>
