[GRASS-dev] hacktober, docs
Vaclav Petras
wenzeslaus at gmail.com
Fri Oct 7 13:14:28 PDT 2022
Sounds good to me. Let's get it quickly there. We will take it down soon
too in any case :-)
On Fri, 7 Oct 2022 at 15:05, Daniel Torres <nobeeakon at gmail.com> wrote:
> What about something like
> [image: imagen.png]
> It is just to have something to show, any suggestion and improvement is
> welcomed. Otherwise, if you think is ok let me know to do the PR
> On Fri, Oct 7, 2022 at 9:12 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> On Fri, 7 Oct 2022 at 09:18, Daniel Torres <nobeeakon at gmail.com> wrote:
>>> I see that all issues tagged with 'Hacktober' are coding related, do you
>>> guys have any idea of non coding stuff that could work? like first-issue
>>> but non coding? mmm I don't know, documentation, missing examples, and so
>>> on?
>> Images for documentation are often missing, e.g.:
>> https://grass.osgeo.org/grass82/manuals/raster_graphical.html
>> (Often it is enough to use the existing example to generate the image.)
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20221007/869ac425/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20221007/869ac425/attachment-0001.png>
