[GRASS-ES] Definir una nueva LOCATION con archivo georreferenciado
Agustin Diez Castillo
Agustin.Diez en uv.es
Lun Mar 24 13:45:06 EDT 2008
Ulises,
Si apunto al shp si que me funciona[1]. Aunque los prj son diferentes y no se decirte si
las diferencias son importantes.
diff borrar.prj Downloads/geod_pts_spm/gdc.prj
1c1
< PROJCS["Lambert Conformal
Conic",GEOGCS["grs80",DATUM["D_North_American_1983",SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["standard_parallel_1",34.33333333333334],PARAMETER["standard_parallel_2",3616666666666666],PARAMETER["latitude_of_origin",33.75],PARAMETER["central_meridian",-79],PARAMETER["false_easting",609601.22],PARAMETER["false_northing",0],UNIT["Meter",1]]
PROJCS["NAD_1983_StatePlane_North_Carolina_FIPS_3200",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",609601.22],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-79.0],PARAMETER["Standard_Parallel_1",34.33333333333334],PARAMETER["Standard_Parallel_2",3616666666666666],PARAMETER["Latitude_Of_Origin",33.75],UNIT["Meter",1.0]]
\ No newline at end of file
[1] g.proj -p georef=/tu_path/gdc.shp location=north_carolina
Trying to open with OGR...
..succeeded.
-PROJ_INFO-------------------------------------------------
name : Lambert Conformal Conic
proj : lcc
datum : nad83
ellps : grs80
lat_1 : 34.33333333333334
lat_2 : 36.16666666666666
lat_0 : 33.75
lon_0 : -79
x_0 : 609601.22
y_0 : 0
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : Meter
units : Meters
meters : 1
> Hola Ulises y todos,
> Ulises Ibarra escribió:
> > Surgió un nuevo problema adicional:
> > 1.- Al querer definir una locación (LOCATION) por medio de código
> > EPSG, en específico la "2264" de North Carolina me sale el
> > siguiente mensaja "WARNING: Please restar GRASS in order find the
> > created location the list (closing it for you)" en una ventana que
> > tiene un botón de "OK" el cual al presionarlo me hace salir del
> > GRASS.
> > Tengo instalado grass versión "6.2.2-ubuntu1" sobre
> > ubuntu8.04beta. Lo mismo me pasa sobre ubuntu7.10.
> Yo aquí no veo nada raro. Es verdad que después de crear la
> Localización cierra la interfaz, pero lo hace porque así puede
> reconocer la nueva Localización creada cuando se reinicia GRASS. He
> probado a crear la misma que la tuya y no he tenido problemas.
> > 2.- Roberto el archivo "gdc.pjr" se encuentra en dentro del
> > archivo "geod_pts_spm.zip" y la dirección de donde lo obtuve es
> > "http://www.grassbook.org/ncexternal/".
> Gracias, no sabía dónde buscar. Ya lo encontré y he intentado crear
> la Localización sin éxito. Creo que pueda ser algún error con la
> interfaz gráfica. Ahora me es imposible. Cuando pueda intento crear
> la Localización usando el comando g.proj y veo a ver is
> verdaderamente es un error del comando o de la interfaz gráfica.
> Un saludo,
> Roberto.
> Pongamos fin a los archivos adjuntos en formato Word.
> ¿Quieres saber por qué? Mira aquí...
> http://www.gnu.org/philosophy/no-word-attachments.es.html
Dr. Agustín Diez Castillo
Departament de Prehistòria i Arqueologia
Fundació General Universitat de València
Phone: +34 963 86 42 42
Avda. Blasco Ibañez, 28 Fax: +34 963 86 42 34
València 46010
Más información sobre la lista de distribución grass-es
