[GRASSGUI] Re: [GRASS5] Suggestions for gui discussion
Michael Barton
michael.barton at asu.edu
Wed Nov 16 01:35:59 EST 2005
Wolf,
I agree that the old interactive xterm interface (including i.points,
d.zoom, and others) needs to be updated. These interactive, mouse intensive
activities would probably benefit most by a new, better integrated GUI.
I'm a little puzzled by your wish for functionality, however. Currently,
GRASS (i.points) does open a pair of side-by-side windows that zoom and pan
synchronously, and permit you to click on the map to be georeferenced in one
window and a corresponding georeferenced point in the other. Alternatively,
you can enter the coordinates for a point to be georeferenced. It also
allows you to check the accuracy of your georeferencing and manage the GCP's
that you use to some degree.
Maybe because your (Cygwin?) system drags so much because of the mouse
polling bug, you've never gotten that far in i.points?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Wolf Bergenheim <wolf+grass at bergenheim.net>
> Date: Tue, 15 Nov 2005 15:23:18 +0200
> To: grass5 <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] Suggestions for gui discussion
> On 11/15/2005 08:11 AM, Michael Barton wrote:
>> Second, for any comments that involve comparisons with the current GRASS GUI
>> (I like this, but...; I really don¹t like this...; I like how x is done
>> better in [name your GIS/interface]), it would be helpful if you could
>> specify which GRASS version you¹re working with. Even better, it would be
>> helpful if you are using the current 6.1 cvs version. The reason is that the
>> GUI (even the TclTk GUI) has evolved considerably since version 6.0 and is a
>> completely different experience from 5.4. This will also help in making
>> improvements to the current UI (which must still serve for awhile) while
>> we¹re developing a new one.
> You asked for it. So here comes. (; Georeferencing UI is EXTREMELY bad.
> When I run I.points I also have to open qgis with another map of the
> same location to get the real co-ordinates. it would be nice to be able
> to force GRASS to open 2 windows. One with the map to be rectified and
> another of the correct location (as an option, since one might not know
> the co-ordinates) (as was my case). Then one should be able to pick a
> point in one window and then either enter the co-ordinates or click in
> the other window for the corresponding window. Oh and BTW the CPU spikes
> up to 100% and my laptop fan starts to go on overdrive everytime I run
> i.points... Is there a busy loop somewhere in the code?
> --Wolf
More information about the grass-gui
