[GRASSGUI] Re: [GRASS5] GRASS GUI - platforms
Riccardo Rigon
riccardo.rigon at ing.unitn.it
Wed Nov 16 11:53:49 EST 2005
Dear guys, I am looking to all of your discussion and following your
respectable opinions. My opinion is
the JGRASS is a valuable GUI alternative to the official GRASS GUI,
especially if you download the CVS version. Moreover it works fine in
Windows, after a port without CGYWIN of many GRASS commands.
As someone pointed out, JGRASS is a Java program and requires the
Java Virtual Machine. This could be a problem for downloading if
someone has a minimal band width. However, if some version of Linux
do not have the JVM, other have and the bandwidth problem is easily
solvable asking a CD or a DVD at minimal cost to Hydrologis.
QT is a valuable choice, however they are year that I wait for the
clarification of its licensing under Windows.
JGRASS is GPL, its interface is highly configurable by using XML and,
by the way, the Java world opens, among the possible developments, a
neat interfacing to databases (for professional use) and to include
some OpenGIS features into the GRASS world.
Actually JGRASS run side by side with GRASS 6.0 and let it live
unmodified.
Best regards,
Riccardo Rigon
On Nov 16, 2005, at 7:59 AM, Michael Barton wrote:
> Running 'natively'--or as natively as possible--will make it MUCH
> easier for
> more people to who want to use GRASS to do so. It will also be
> easier to
> learn more of the complexities of GIS and spatial analysis if they can
> install it easily and simply run it easily.
> TclTk is somewhat easy to work with because it doesn't have to be
> compiled.
> HOWEVER, I now have 3 versions of TclTk on my Mac--the one that
> comes from
> Apple (that GRASS does not use), the X11 version that I prefer, and
> the aqua
> version that Lorenzo Moretti has used to give GRASS an optionally more
> Mac-like appearance. Windows users need 2 versions of TclTk because
> the
> version that comes with Cygwin doesn't work with GRASS. (Oh yeah
> and they
> need Cygwin too). Some Linux users need version 8.3 in addition to the
> version 8.4 that comes with their system. This is a mess. If we
> were to go
> with TclTk, this would have to be cleaned up. But I don't know if it's
> possible.
> I also have heard that QT is making an open source version
> available for
> Windows, but don't know the status of that. This is a pretty
> critical issue,
> but perhaps solved already.
> As someone else mentioned, GIMP works pretty transparently on my
> Mac, even
> though it runs under X11. So does Inkscape (also GTK I think).
> Apple gives
> away a Mac-specific version of X11, so this is not a problem
> AFAICT. I've
> seen GIMP run on Windows XP and it appears to run natively (ie., no
> need for
> Cygwin or x11 emulation). GTK seems to be widely standard on most
> Linux
> systems too.
> Someone also mentioned wxwindows as a platform candidate. I haven't
> heard of
> this. Has anyone else?
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: William Kyngesburye <woklist at kyngchaos.com>
>> Reply-To: William Kyngesburye <kyngchaos at kyngchaos.com>
>> Date: Tue, 15 Nov 2005 09:43:08 -0600
>> To: <grass5 at grass.itc.it>, <grassgui at grass.itc.it>
>> Subject: Re: [GRASS5] GRASS GUI
>> I think the GUI toolkit should run *natively* cross-platform.
>> GTK: X11. That is, on Mac OS X is requires the X11 environment. I
>> saw the beginnings of a native Mac port, but it could take a while.
>> I'm not sure how it works on Windows, cygwin? I think I saw a well
>> developed native port.
>> Tcl/Tk: X11. There are native builds of this on Mac and Windows.
>> But, when I tried to use that on Mac OS X I ran into conflicts
>> between X11 stuff and Mac OS X. GRASS would have to be completely
>> divorced from X11.
>> Qt: native from the ground up. I just started playing with qgis.
>> From the binaries, it's a Mac application (or Windows, or X11),
>> though the GUI widgets are a lot like Windows. I'm trying a build
>> from source (so I can update GDAL in it) and maybe there are some
>> settings to use some more native versions of things (like the open/
>> save dialogs).
>> As for a choice of GUI kits, I wonder if would be possible to
>> abstract the GUI functions in a GRASS library, and that will use
>> whichever GUI kit was built into that copy of GRASS. It might even
>> then be possible to plug binaries of the GRASS GUI library into a
>> GRASS binary to switch between GUIs. Maybe start with Qt and add
>> others later. Just a thought.
>> On Nov 14, 2005, at 11:33 PM, Sajith VK wrote:
>>> Tool kit(TK/GTK/QT)
>>> Custom application development is very important in
>>> GIS. Hence selection of toolkit decides the way in which
>>> we can develop custom applications based on GRASS. Now each
>>> programmer has his own choice for toolkit. I like Gnome(and uses
>>> Gtk),
>>> and similarly someone else may like KDE(and use QT).
>>> So first a generic outline need to be developed. Later
>>> it should be implemented in both Qt and Gtk(atleast). So we
>>> can have a base application(say grass) and a set of GUI's
>>> (ggrass,kgrass,wxgrass etc). Initially it can be implemented
>>> in one toolkit and later extend to all.
>> http://www.kyngchaos.com/
>> "History is an illusion caused by the passage of time, and time is an
>> illusion caused by the passage of history."
>> - Hitchhiker's Guide to the Galaxy
> grassgui mailing list
> http://grass.itc.it/mailman/listinfo/grassgui
__________________________________________________________
Universita` di Trento Dipartimento di Ingegneria Civile e
Ambientale
CUDAM
Via Mesiano, 77 Trento (ITALIA)
e-mail: riccardo.rigon at ing.unitn.it
ph: +390461882610 fax:+390461882672
web page: http://www.ing.unitn.it/dica/hp/?
user=rigon
More information about the grass-gui
