[GRASSGUI] Re: [grass-addons] r659 - trunk/grassaddons/gui/gui_modules
Wed May 16 13:11:09 EDT 2007
Michael Barton wrote:
> Are you thinking that we should change all calls to GRASS commands to use
> the new cmd module?
> > +        cmdString = "g.region -ugp region=%s" % wind
> > +        p = cmd.Command (cmdString)
This interface is broken, and needs to be replaced.
           self.module = subprocess.Popen(self.cmd, shell=True,
Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong.
Just how clearly do I have to say this before it sinks in:
	DO NOT USE THE SHELL
Using the shell means problems with spaces, quotes and other shell
metacharacters. There is no reason to use it. So don't.
More information about the grass-gui mailing list
