[GRASSGUI] Re: [grass-addons] r659 -
trunk/grassaddons/gui/gui_modules
Martin Landa
landa.martin at gmail.com
Wed May 16 13:15:01 EDT 2007
Glynn,
2007/5/16, Glynn Clements <glynn at gclements.plus.com>:
> > Are you thinking that we should change all calls to GRASS commands to use
> > the new cmd module?
> > > + cmdString = "g.region -ugp region=%s" % wind
> > > + p = cmd.Command (cmdString)
> This interface is broken, and needs to be replaced.
> self.module = subprocess.Popen(self.cmd, shell=True,
> Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong.
> Just how clearly do I have to say this before it sinks in:
> DO NOT USE THE SHELL
> Using the shell means problems with spaces, quotes and other shell
> metacharacters. There is no reason to use it. So don't.
OK, then we need to fix Command class... (I will look at it tomorrow)
Martin
> grassgui mailing list
> grassgui at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassgui
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
More information about the grass-gui
