[GRASSGUI] wxgrass does not see wx on import
Daniel Calvelo dca.gis at gmail.com
Sat May 19 00:11:13 EDT 2007
Brad,
Which widget was it? If it's part of the contrib widgets in wx2.8,
that's manageable.
Did you try setting PYTHONPATH with a hand-compiled version of wxpython?
Daiel.
On 5/18/07, Brad Douglas <rez at touchofmadness.com> wrote:
> I had similar problems after installing the RPMs I built, but I got a
> bit further until it complained about a specific 'widget'.  I traced it
> back to a requirement on python-2.5+ (that's how it appeared).  Please
> correct me if I'm wrong because I'd really like to get this working with
> GRASS[1].
> [1] I can't upgrade python without upgrading to an unstable development
> version of the OS due to massive dependencies.  Not something I want to
> do and still be able to build GRASS RPMs reliably.
> On Thu, 2007-05-17 at 14:26 +0700, Yann wrote:
> > Hi,
> > System: Debian unstable (from Kanotix originally)
> > - installed wxgtk2.6, had a problem, wxgrass could not find wx.combo.
> > - compiled from source wxpython2.8.0
> > (./configure --prefix=/usr --enable-combobox --with-gtk --with-gnomeprint --with-opengl --enable-geometry --enable-display ;
> > make ; make install)
> > - wxgrass does not find wx
> > GRASS 6.3.cvs (biwago):~ > wxgrass
> > Traceback (most recent call last):
> >   File "/usr/local/grass-6.3.cvs/etc/wx/wxgui.py", line 11, in ?
> >     import wx
> > ImportError: No module named wx
> > Anybody can tell me the missing link to make the new wx visible to python?
> Brad Douglas <rez touchofmadness com>                    KB8UYR/6
> Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
> grassgui mailing list
> grassgui at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassgui
-- Daniel Calvelo Aros
More information about the grass-gui mailing list
