[GRASSGUI] GEM wizard in wxPython
Jachym Cepicky jachym.cepicky at gmail.com
Mon May 21 06:44:20 EDT 2007
basically, there are two possibilities: Use standard python packages or
using CLI commands. In current wxGRASS gui, commands are used, to avoid
new dependences. So, I would vote for some "wget+parsing" sollution.
For example, how to create wizard using wxpython, see wizard example in
wxpython demo
(http://prdownloads.sourceforge.net/wxpython/wxPython-demo-2.8.4.0.tar.bz2)
I put together nearly-working new location wizard, if you will be able
to follow the code.
Jachym
Yann píše v Po 21. 05. 2007 v 17:26 +0700:
> Hi all,
> Anybody could "mentor" a wxPython newbie into getting a GEM Wizard up and
> running?
> Aim:
> 1-List some predefined Extensions
> 2-Select any, then download it
> 3-Run Gem on the .tgz file downloaded (supposed you already are in root)
> Thanks
> Yann
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
More information about the grass-gui mailing list
