[GRASSGUI] GEM wizard in wxPython
Yann yann.chemin at gmail.com
Mon May 21 07:12:18 EDT 2007
Hi Jachym,
Yes, the wget+parsing is tempting, i just need to figure out how to do all
that...
could you tell me where i can find your New Location Wizard, maybe I'll get a
hint to do that for GEM.
Thanks
Yann
On Monday 21 May 2007 17:44, Jachym Cepicky wrote:
> Hi,
> basically, there are two possibilities: Use standard python packages or
> using CLI commands. In current wxGRASS gui, commands are used, to avoid
> new dependences. So, I would vote for some "wget+parsing" sollution.
> For example, how to create wizard using wxpython, see wizard example in
> wxpython demo
> (http://prdownloads.sourceforge.net/wxpython/wxPython-demo-2.8.4.0.tar.bz2)
> I put together nearly-working new location wizard, if you will be able
> to follow the code.
> Jachym
> Yann píše v Po 21. 05. 2007 v 17:26 +0700:
> > Hi all,
> > Anybody could "mentor" a wxPython newbie into getting a GEM Wizard up and
> > running?
> > Aim:
> > 1-List some predefined Extensions
> > 2-Select any, then download it
> > 3-Run Gem on the .tgz file downloaded (supposed you already are in root)
> > Thanks
> > Yann
Yann Chemin
Sainte-Anne d'Auray, France
More information about the grass-gui mailing list
