[GRASS-PSC] Write access to GRASS-SVN repository
hmitaso at ncsu.edu hmitaso at ncsu.edu
Sun May 29 16:47:04 EDT 2011
This may be a little late (I am still traveling, at this moment in
Netherlands) but I vote
+1 as well.
Anna, I would like to ask you, please test everything that you are going
to submit to the main SVN with at least two different DEMs to make sure it
works correctly, I will try to regularly update trunk
and test as well as soon as I get back,
Helena
> 2011/5/23 Anna Kratochvílová <KratochAnna at seznam.cz>:
>> Hello,
>> my name is Anna Kratochvilova and I'm asking you for the write access to
>> the main GRASS-SVN
>> repository. I need access because wx.psmap (I'm its author) has moved to
>> trunk from addons.
>> Another reason is that I'm going to work on wxNviz within Google Summer
>> of Code. My mentor
>> is Martin Landa and he will check my commits.
> Dear PSC members,
> I'll shortly close the voting procedure. Please vote of you didn't do so
> already.
> thanks
> Markus
> grass-psc mailing list
> grass-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-psc
More information about the grass-psc mailing list
