[GRASS-PSC] Fwd: GRASS-Addons-SVN repository write access request
Martin Landa landa.martin at gmail.com
Thu Oct 8 08:07:09 PDT 2015
2015-10-08 16:40 GMT+02:00 Giuseppe Amatulli <giuseppe.amatulli at gmail.com>:
> May be possible for now leave it in bash and allows the user to install it
> by using g.extension ?
no, currently it's not possible. As I said GRASS 7 building system
supports only Python scripts. Ie. g.extension fails with:
Fetching <r.stream.variables> from GRASS GIS Addons repository (be patient)...
Compiling...
make: *** No rule to make target
`/tmp/grass7-landa-19140/tmpZOruoE/r.stream.variables/scripts/r.stream.variables',
needed by `script'.  Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
There are only two options:
1) rewrite your scripts to Python
2) add support to GRASS building system for Bash script (if you want
it please fill the ticket on Trac)
Martin
PS: Let's move this discussion from grass-psc ML to grass-user or grass-dev!
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
More information about the grass-psc mailing list
