[GRASS-PSC] SVN write access request to contribute GRASS add-on module
Thomas Huld
thomas.huld at gmail.com
Wed Jan 27 12:26:12 PST 2016
Hello,
I would like to contribute a GRASS add-on module. My osgeo_id is 'tomhuld',
and I have read and accepted the RFC/2 document.
The module, "r.jpdf", calculates the joint probability function of two
series of raster maps and outputs a 2D set of raster maps with the binned
probabilities according to user-specified ranges of the two independent
variables.
I'm not sure whom to recommend as "mentor". I used the r.series code as a
guideline for writing the code.
I have attached the code which compiles and runs under GRASS 7.0.2.
Thomas Huld
Joint Research Centre of the European Commission
Ispra, Italy
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20160127/518e0d9b/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20160127/518e0d9b/attachment.bin>
More information about the grass-psc
