[GRASS-PSC] [Motion] Approve Linda's student grant final report and issue the second payment
Markus Neteler
neteler at osgeo.org
Fri Mar 4 04:08:38 PST 2022
+1 Markus
Thanks Linda and mentors!
On Thu, Mar 3, 2022 at 11:30 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> Dear PSC,
> Linda has just completed her project for the student grant and submitted the final report (I FWD it here in case you missed it).
> I hereby propose to approve her final report and issue the second half of the payment. Big thanks to Linda and her mentors for your work and commitment!
> I start with my +1 !!
> Vero
> ---------- Forwarded message ---------
> De: Linda Kladivová <L.Kladivova at seznam.cz>
> Date: mié, 2 mar 2022 a las 19:19
> Subject: [GRASS-dev] Final report for Mini project 2022: Redesigning a map display status bar combo box into a new settings dialog
> To: <grass-dev at lists.osgeo.org>, <grass-user at lists.osgeo.org>
> Hello everyone,
> I am sending my final Mini Project report. The more detailed version with permanent links on GitHub PRs and with several screenshots can be found at the project wiki [1].
> Abstract:
> Especially for Single-Window GUI, the Map Display status bar needs to be lightened up a bit since in the case of opening more Map Display notebook pages the check box on the right side of the status bar gets shrunk. The solution is to remove the combo box in the status bar occupying too much space and implement a new Map Display settings dialog accessible from the top map display toolbar.
> The state of the art BEFORE the start of Mini Project:
> At this moment, the status bar at the bottom of the Map Display window consists of the text/widget section, the combo box, the mask and the check box. For the Single-Window GUI, the number of widgets must be reduced so that the check box on the right side of the status bar is not shrunk.
> The state of the art AFTER Mini Project:
> The new Map Display settings dialog is introduced. The main task of this dialog is to manage General Map Display settings and Statusbar settings. It implies that the status bar combobox is not needed anymore because we can find all Map Display settings including status bar customization in the new dialog.
> Next Steps:
> Other possible improvements related to status bar stuff could be:
> Moving Projection page from GUI settings to the Map Display status bar settings
> Adding context menu for status bar customization
> Adding EPSG code label of current location to the main status bar
> Merging „Go to coordinates X, Y“ and „Coordinates“ item into one widget
> Permanent links and screenshots can be found at [2] and [3].
> [1] https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar
> [2] https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar#FinalReport
> [3] https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar#BrandnewScreenshotsofMapDisplaySettingsdialog
> Have a nice week,
> Linda
> grass-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-dev
> grass-psc mailing list
> grass-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-psc
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
More information about the grass-psc
