[GRASS-PSC] [Motion] Approve Linda's student grant final report and issue the second payment
Vaclav Petras wenzeslaus at gmail.com
Fri Mar 4 06:21:01 PST 2022
+1 for Linda!
On Fri, Mar 4, 2022, 7:09 AM Markus Neteler <neteler at osgeo.org> wrote:
> +1 Markus
> Thanks Linda and mentors!
> On Thu, Mar 3, 2022 at 11:30 PM Veronica Andreo <veroandreo at gmail.com>
> wrote:
> > Dear PSC,
> > Linda has just completed her project for the student grant and submitted
> the final report (I FWD it here in case you missed it).
> > I hereby propose to approve her final report and issue the second half
> of the payment. Big thanks to Linda and her mentors for your work and
> commitment!
> > I start with my +1 !!
> > Vero
> > ---------- Forwarded message ---------
> > De: Linda Kladivová <L.Kladivova at seznam.cz>
> > Date: mié, 2 mar 2022 a las 19:19
> > Subject: [GRASS-dev] Final report for Mini project 2022: Redesigning a
> map display status bar combo box into a new settings dialog
> > To: <grass-dev at lists.osgeo.org>, <grass-user at lists.osgeo.org>
> > Hello everyone,
> > I am sending my final Mini Project report. The more detailed version
> with permanent links on GitHub PRs and with several screenshots can be
> found at the project wiki [1].
> > Abstract:
> > Especially for Single-Window GUI, the Map Display status bar needs to be
> lightened up a bit since in the case of opening more Map Display notebook
> pages the check box on the right side of the status bar gets shrunk. The
> solution is to remove the combo box in the status bar occupying too much
> space and implement a new Map Display settings dialog accessible from the
> top map display toolbar.
> > The state of the art BEFORE the start of Mini Project:
> > At this moment, the status bar at the bottom of the Map Display window
> consists of the text/widget section, the combo box, the mask and the check
> box. For the Single-Window GUI, the number of widgets must be reduced so
> that the check box on the right side of the status bar is not shrunk.
> > The state of the art AFTER Mini Project:
> > The new Map Display settings dialog is introduced. The main task of this
> dialog is to manage General Map Display settings and Statusbar settings. It
> implies that the status bar combobox is not needed anymore because we can
> find all Map Display settings including status bar customization in the new
> dialog.
> > Next Steps:
> > Other possible improvements related to status bar stuff could be:
> > Moving Projection page from GUI settings to the Map Display status bar
> settings
> > Adding context menu for status bar customization
> > Adding EPSG code label of current location to the main status bar
> > Merging „Go to coordinates X, Y“ and „Coordinates“ item into one widget
> > Permanent links and screenshots can be found at [2] and [3].
> > [1]
> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar
> > [2]
> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar#FinalReport
> > [3]
> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar#BrandnewScreenshotsofMapDisplaySettingsdialog
> > Have a nice week,
> > Linda
> > grass-dev mailing list
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
> > grass-psc mailing list
> > grass-psc at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-psc
> Markus Neteler, PhD
> https://www.mundialis.de - free data with free software
> https://grass.osgeo.org
> https://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20220304/25714f3c/attachment-0001.html>
More information about the grass-psc mailing list
