[GRASS-PSC] [Motion] Approve Linda's student grant final report and issue the second payment
    Huidae Cho
    grass4u at gmail.com
    Fri Mar  4 07:58:07 PST 2022
+1
Huidae
Huidae Cho, Ph.D., GISP
GRASS GIS Developer
https://idea.isnew.info/
Sent from my phone
On Fri, Mar 4, 2022, 9:21 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> +1 for Linda!
> On Fri, Mar 4, 2022, 7:09 AM Markus Neteler <neteler at osgeo.org> wrote:
>> +1 Markus
>> Thanks Linda and mentors!
>> On Thu, Mar 3, 2022 at 11:30 PM Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>> > Dear PSC,
>> > Linda has just completed her project for the student grant and
>> submitted the final report (I FWD it here in case you missed it).
>> > I hereby propose to approve her final report and issue the second half
>> of the payment. Big thanks to Linda and her mentors for your work and
>> commitment!
>> > I start with my +1 !!
>> > Vero
>> > ---------- Forwarded message ---------
>> > De: Linda Kladivová <L.Kladivova at seznam.cz>
>> > Date: mié, 2 mar 2022 a las 19:19
>> > Subject: [GRASS-dev] Final report for Mini project 2022: Redesigning a
>> map display status bar combo box into a new settings dialog
>> > To: <grass-dev at lists.osgeo.org>, <grass-user at lists.osgeo.org>
>> > Hello everyone,
>> > I am sending my final Mini Project report. The more detailed version
>> with permanent links on GitHub PRs and with several screenshots can be
>> found at the project wiki [1].
>> > Abstract:
>> > Especially for Single-Window GUI, the Map Display status bar needs to
>> be lightened up a bit since in the case of opening more Map Display
>> notebook pages the check box on the right side of the status bar gets
>> shrunk. The solution is to remove the combo box in the status bar occupying
>> too much space and implement a new Map Display settings dialog accessible
>> from the top map display toolbar.
>> > The state of the art BEFORE the start of Mini Project:
>> > At this moment, the status bar at the bottom of the Map Display window
>> consists of the text/widget section, the combo box, the mask and the check
>> box. For the Single-Window GUI, the number of widgets must be reduced so
>> that the check box on the right side of the status bar is not shrunk.
>> > The state of the art AFTER Mini Project:
>> > The new Map Display settings dialog is introduced. The main task of
>> this dialog is to manage General Map Display settings and Statusbar
>> settings. It implies that the status bar combobox is not needed anymore
>> because we can find all Map Display settings including status bar
>> customization in the new dialog.
>> > Next Steps:
>> > Other possible improvements related to status bar stuff could be:
>> > Moving Projection page from GUI settings to the Map Display status bar
>> settings
>> > Adding context menu for status bar customization
>> > Adding EPSG code label of current location to the main status bar
>> > Merging „Go to coordinates X, Y“ and „Coordinates“ item into one widget
>> > Permanent links and screenshots can be found at [2] and [3].
>> > [1]
>> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar
>> > [2]
>> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar#FinalReport
>> > [3]
>> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar#BrandnewScreenshotsofMapDisplaySettingsdialog
>> > Have a nice week,
>> > Linda
>> > _______________________________________________
>> > grass-dev mailing list
>> > https://lists.osgeo.org/mailman/listinfo/grass-dev
>> > grass-psc mailing list
>> > grass-psc at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/grass-psc
>> Markus Neteler, PhD
>> https://www.mundialis.de - free data with free software
>> https://grass.osgeo.org
>> https://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20220304/2507c0b2/attachment.html>
More information about the grass-psc
