[GRASS-PSC] [Motion] Approve Linda's final report and issue the 2nd payment
Helena Mitasova hmitaso at ncsu.edu
Tue May 14 13:22:04 PDT 2024
+1, Helena
> On May 14, 2024, at 2:36 PM, Vaclav Petras via grass-psc <grass-psc at lists.osgeo.org> wrote:
> +1, Vaclav
> On Tue, 14 May 2024 at 13:46, Anna Petrášová via grass-psc <grass-psc at lists.osgeo.org <mailto:grass-psc at lists.osgeo.org>> wrote:
> +1 for me!
> Anna
> On Tue, May 14, 2024 at 12:29 PM Veronica Andreo via grass-psc <grass-psc at lists.osgeo.org <mailto:grass-psc at lists.osgeo.org>> wrote:
> Dear PSC,
> Linda has just completed her student grant project and submitted the final report (forwarded below).
> I hereby propose to approve her final report and issue the second payment.
> Big thanks to Linda and her mentors for their work and commitment! Thanks as well to those testing and providing feedback! Very nice work Linda!! Congratulations!
> I start with my +1
> Vero
> ---------- Forwarded message ---------
> De: Linda Karlovská via grass-dev <grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>>
> Date: lun, 13 may 2024 a las 14:15
> Subject: [GRASS-dev] Final reports for Mini project 2024: Easy command history navigation through the History browser panel
> To: GRASS developers list <grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>>, <grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>>
> Hello everyone,
> I am sending the short report for weeks 7-9 and the final report of the Mini Project devoted to improving GUI, particularly the History browser pane. The goal of this project was to provide a user with a better command history navigation and I think it was quite successful :-), you can have a look at screenshots here: [1]
> What did I complete during weeks 7-9?
> I completed the PR  <https://github.com/OSGeo/grass/pull/3421>[2] implementing time node branching in the history tree. Moreover, I also added a button to update the current region based on the region used during command execution (PR  <https://github.com/OSGeo/grass/pull/3679>[3]). Besides that, I introduced icons representing command status (success, failed, running, aborted, unknown) and added them in front of history entries (PR  <https://github.com/OSGeo/grass/pull/3679>[4]).
> Thanks Anna Petrasova for the valuable comments in the reviews!
> Final report
> Abstract
> This project builds upon the work initiated during the OSGeo sprint in Prague in the summer of 2023, which focused on creating a new History Browser panel to facilitate access to the command history. Although the new History Browser panel became available in the GRASS development version starting December 8th (refer to the PR [5]), initially it provided only a basic, single-level display of commands from the history log, with the capability to relaunch commands but lacking detailed command information. This project aims to enhance the basic functionality by incorporating several improvements.
> The state of the art BEFORE the start of the Mini project:
> The History Browser panel displayed a simple tree of command entries loaded from a plain-text history log. It had only the capability to relaunch commands.
> The state of the art AFTER Mini project:
> Implemented changes include:
> Transitioning the plain text format of the history log (.wxgui_history) to JSON format, allowing more information to be stored for each executed command. Newly, the log stores information about the timestamp, command status, runtime duration, region settings, and mask usage.
> Instead of implementing the initially planned context option "Show Info" and displaying a small dialog with process information, the history pane was redesigned into two sections. The upper part features the  history tree, while the lower part includes two static boxes presenting information stored in the history log. The first box contains general details, and the second box displays the computational region during command execution.
> Adding a symbol in front of each command in the tree based on the command's status.
> Branching the tree based on the date of command execution - tree is branched into days and sorted from the Today node to older nodes. Command nodes are sorted from the oldest to the newest.
> The task of filtering commands based on status was not addressed during the project due to higher-priority issues that emerged:
> Adding the "Update current region" button, which dynamically updates the region based on the executed command and its information stored in the JSON-formatted history log.
> Introducing a new Delete option in the command tree
> Rearranging the Export History button
> Next Steps:
> Possible improvements for the History browser pane:
> Fixing of command status for nonsense entries (already noted here: [6]):
> Sorting the commands in the history tree from the newest to oldest (seems more logical)
> Implementing efficient refresh methods (currently all nodes are refreshed when adding a command)
> Showing the complete error text if a command fails. (Now there is a “failed” status written but no clue what actually happened).
> Adding the new combo box restricting the filtering based on the command status
> Adding the Copy context menu option to command nodes
> Permanent links to GitHub PRs and screenshots of the improved History Browser pane can be found at [7] and [1].
> [1] https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/EasyCommandHistoryNavigation#ScreenshotsofHistoryBrowserimprovements <https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/EasyCommandHistoryNavigation#ScreenshotsofHistoryBrowserimprovements>
> [2] https://github.com/OSGeo/grass/pull/3622 <https://github.com/OSGeo/grass/pull/3622>
> [3] https://github.com/OSGeo/grass/pull/3421 <https://github.com/OSGeo/grass/pull/3421>
> [4] https://github.com/OSGeo/grass/pull/3679 <https://github.com/OSGeo/grass/pull/3679>
> [5] https://github.com/OSGeo/grass/pull/3234 <https://github.com/OSGeo/grass/pull/3234https:/github.com/OSGeo/grass/pull/3234>
> [6] https://github.com/OSGeo/grass/issues/3698 <https://github.com/OSGeo/grass/issues/3698>
> [7] https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/EasyCommandHistoryNavigation#FinalReport <https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/EasyCommandHistoryNavigation#FinalReport>
> Have a nice week.
> Linda
> grass-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-dev <https://lists.osgeo.org/mailman/listinfo/grass-dev>
> Dra. Verónica Andreo
> Investigadora Adjunta de CONICET
> Instituto Gulich (CONAE - UNC)
> Centro Espacial Teófilo Tabanera (CETT)
> Falda del Cañete - Córdoba, Argentina
> +54 3547 400000 int. 1153
> https://veroandreo.gitlab.io/ <https://veroandreo.gitlab.io/>
> grass-psc mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-psc <https://lists.osgeo.org/mailman/listinfo/grass-psc>
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20240514/fe49cb78/attachment.htm>
More information about the grass-psc mailing list
