[GRASS-PSC] [Motion] Approve Linda's final report and issue the 2nd payment
Huidae Cho
grass4u at gmail.com
Tue May 14 13:23:52 PDT 2024
+1
Huidae
Huidae Cho, Ph.D., GISP
GRASS GIS Developer
https://idea.isnew.info/
Sent from my phone
On Tue, May 14, 2024, 2:22 PM Helena Mitasova via grass-psc <
grass-psc at lists.osgeo.org> wrote:
> +1, Helena
> On May 14, 2024, at 2:36 PM, Vaclav Petras via grass-psc <
> +1, Vaclav
> On Tue, 14 May 2024 at 13:46, Anna Petrášová via grass-psc <
>> +1 for me!
>> Anna
>> On Tue, May 14, 2024 at 12:29 PM Veronica Andreo via grass-psc <
>>> Dear PSC,
>>> Linda has just completed her student grant project and submitted the
>>> final report (forwarded below).
>>> I hereby propose to approve her final report and issue the second
>>> payment.
>>> Big thanks to Linda and her mentors for their work and commitment!
>>> Thanks as well to those testing and providing feedback! Very nice work
>>> Linda!! Congratulations!
>>> I start with my +1
>>> Vero
>>> ---------- Forwarded message ---------
>>> De: Linda Karlovská via grass-dev <grass-dev at lists.osgeo.org>
>>> Date: lun, 13 may 2024 a las 14:15
>>> Subject: [GRASS-dev] Final reports for Mini project 2024: Easy command
>>> history navigation through the History browser panel
>>> To: GRASS developers list <grass-dev at lists.osgeo.org>, <
>>> grass-user at lists.osgeo.org>
>>> Hello everyone,
>>> I am sending the short report for weeks 7-9 and the final report of the
>>> Mini Project devoted to improving GUI, particularly the History browser
>>> pane. The goal of this project was to provide a user with a better command
>>> history navigation and I think it was quite successful :-), you can have a
>>> look at screenshots here: [1]
>>> *What did I complete during weeks 7-9?*
>>> I completed the PR <https://github.com/OSGeo/grass/pull/3421>[2]
>>> implementing time node branching in the history tree. Moreover, I also
>>> added a button to update the current region based on the region used during
>>> command execution (PR <https://github.com/OSGeo/grass/pull/3679>[3]).
>>> Besides that, I introduced icons representing command status (success,
>>> failed, running, aborted, unknown) and added them in front of history
>>> entries (PR <https://github.com/OSGeo/grass/pull/3679>[4]).
>>> Thanks Anna Petrasova for the valuable comments in the reviews!
>>> *Final report*
>>> *Abstract*
>>> This project builds upon the work initiated during the OSGeo sprint in
>>> Prague in the summer of 2023, which focused on creating a new History
>>> Browser panel to facilitate access to the command history. Although the new
>>> History Browser panel became available in the GRASS development version
>>> starting December 8th (refer to the PR [5]), initially it provided only a
>>> basic, single-level display of commands from the history log, with the
>>> capability to relaunch commands but lacking detailed command information.
>>> This project aims to enhance the basic functionality by incorporating
>>> several improvements.
>>> *The state of the art BEFORE the start of the Mini project:*
>>> The History Browser panel displayed a simple tree of command entries
>>> loaded from a plain-text history log. It had only the capability to
>>> relaunch commands.
>>> *The state of the art AFTER Mini project:*
>>> Implemented changes include:
>>> - Transitioning the plain text format of the history log
>>> (.wxgui_history) to JSON format, allowing more information to be stored for
>>> each executed command. Newly, the log stores information about the
>>> timestamp, command status, runtime duration, region settings, and mask
>>> usage.
>>> - Instead of implementing the initially planned context option "Show
>>> Info" and displaying a small dialog with process information, the history
>>> pane was redesigned into two sections. The upper part features the history
>>> tree, while the lower part includes two static boxes presenting information
>>> stored in the history log. The first box contains general details, and the
>>> second box displays the computational region during command execution.
>>> - Adding a symbol in front of each command in the tree based on the
>>> command's status.
>>> - Branching the tree based on the date of command execution - tree
>>> is branched into days and sorted from the Today node to older nodes.
>>> Command nodes are sorted from the oldest to the newest.
>>> The task of filtering commands based on status was not addressed during
>>> the project due to higher-priority issues that emerged:
>>> - Adding the "Update current region" button, which dynamically
>>> updates the region based on the executed command and its information stored
>>> in the JSON-formatted history log.
>>> - Introducing a new Delete option in the command tree
>>> - Rearranging the Export History button
>>> *Next Steps:*
>>> Possible improvements for the History browser pane:
>>> - Fixing of command status for nonsense entries (already noted here:
>>> [6]):
>>> - Sorting the commands in the history tree from the newest to oldest
>>> (seems more logical)
>>> - Implementing efficient refresh methods (currently all nodes are
>>> refreshed when adding a command)
>>> - Showing the complete error text if a command fails. (Now there is
>>> a “failed” status written but no clue what actually happened).
>>> - Adding the new combo box restricting the filtering based on the
>>> command status
>>> - Adding the Copy context menu option to command nodes
>>> Permanent links to GitHub PRs and screenshots of the improved History
>>> Browser pane can be found at [7] and [1].
>>> [1]
>>> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/EasyCommandHistoryNavigation#ScreenshotsofHistoryBrowserimprovements
>>> [2] https://github.com/OSGeo/grass/pull/3622
>>> [3] https://github.com/OSGeo/grass/pull/3421
>>> [4] https://github.com/OSGeo/grass/pull/3679
>>> [5] https://github.com/OSGeo/grass/pull/3234
>>> <https://github.com/OSGeo/grass/pull/3234https:/github.com/OSGeo/grass/pull/3234>
>>> [6] https://github.com/OSGeo/grass/issues/3698
>>> [7] https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/
>>> EasyCommandHistoryNavigation#FinalReport
>>> Have a nice week.
>>> Linda
>>> grass-dev mailing list
>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
>>> Dra. Verónica Andreo
>>> Investigadora Adjunta de CONICET
>>> Instituto Gulich (CONAE - UNC)
>>> Centro Espacial Teófilo Tabanera (CETT)
>>> Falda del Cañete - Córdoba, Argentina
>>> +54 3547 400000 int. 1153
>>> https://veroandreo.gitlab.io/
>>> grass-psc mailing list
>>> https://lists.osgeo.org/mailman/listinfo/grass-psc
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20240514/5bddd7c5/attachment-0001.htm>
More information about the grass-psc
