[GRASS-PSC] GitHub supports limiting open PRs per user
Anna Petrášová kratochanna at gmail.com
Thu Aug 20 06:09:03 PDT 2026
Added!
On Thu, Aug 20, 2026 at 8:19 AM Veronica Andreo via grass-psc <
grass-psc at lists.osgeo.org> wrote:
> Perhaps a topic to add here:
> https://grasswiki.osgeo.org/wiki/PSC_Meeting_2026-08-14 for the meeting
> tomorrow
> El jue, 20 ago 2026 a las 7:52, Edouard Choinière via grass-psc (<
> grass-psc at lists.osgeo.org>) escribió:
>> For now, to avoid a situation where we would get stormed by a single user
>> (and help with the cleanup afterwards), the limit I had set when the
>> setting came out is 20 (to not bother existing collaborators too much). We
>> can choose a number between 1 and 1000.
>> We can also add users to a bypass list. I didn’t do anything on that,
>> unless I had gotten feedback about the friction. That way we are still
>> “protected” by an account being hijacked, even if was one of the closer
>> collaborators.
>> Edouard Choinière
>> Le 20 août 2026 à 06:46, Linda Karlovská via grass-psc <
>> grass-psc at lists.osgeo.org> a écrit :
>> Hi everyone,
>> I just found out that GitHub now has a setting that allows us to limit
>> the number of open PRs a user can have in a repository.
>> https://github.blog/changelog/2026-06-17-limit-open-pull-requests-for-users-without-write-access/?utm_source=chatgpt.com
>> We can set a maximum number of open PRs per user, and there should also
>> be an option to create a bypass list for trusted contributors.
>> We talked about the increasing number of PRs with Anna and Vashek some
>> time ago, so maybe we should consider trying this for GRASS.
>> It might also potentially improve the quality of contributions if someone
>> can only have, say, two or three PRs open at a time, they might be more
>> likely to think about what really belongs in GRASS and what might be
>> unnecessary.
>> Best,
>> Linda
>> grass-psc mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-psc
> Dra. Verónica Andreo
> Investigadora Adjunta de CONICET
> Instituto Gulich (CONAE - UNC)
> Centro Espacial Teófilo Tabanera (CETT)
> Falda del Cañete - Córdoba, Argentina
> +54 3547 400000 int. 1153
> https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20260820/1fd8b437/attachment.htm>
More information about the grass-psc mailing list
